Is the TagXplorer software PC/SC compatible?
Cyrille
Hello All,
Hope you are well.
I would like to know if the TagXplorer software is PC/SC compatible or if it uses a proprietary protocol.
Indeed, I tried to make the application work with the Puck Base PC/SC reader from SpringCard, which is a PC/SC compatible reader, but the application tells me that the reader is not supported.
In the Release-Notes-v1.2.txt file, I saw this : "Support for Identiv CLOUD PC/SC reader "uTrust 3701 F CL Reader".
Could someone please answer me ?
Thank you.
