ISO15693 6.6 kbps
ISO15693 6.6 kbps
markfreeman
Using the CLEV6630B Eval board and NFC Cockpit for reading ISO15693 tags, I see the built-in configurations support 53 kbps and 26 kbps.  Are there register settings in the CLRC66303 that support 6.6 kbps?
Jonathan_Iglesias
Dear Mark Freeman,
as you can see in the data sheet the 6.6 communication is not supported
Jonathan
