How to reuses the modules on NHS3100 with LPCXpresso?
1,045件の閲覧回数
aresmarser
Hi Sir,
I am now working on NHS3100 with LPCXpresso and here I have a question.
In the document "NHS31xxSoftwareOverview.pdf", it talks about the module reuse but not mentions how to reuse the modules?
For example, I download the SDK "release_mra2_10_1_nhs3100.zip" so I study the examples such as "app_demo_dp_blinky".
I want to add/reuse the module "trace" in "app_demo_dp_blinky" example project. But how should I operate/config to add the module into my project?
Could you be kindly to provide some guide?
Sorry I am a newer in this field.
I am eager to get your support.
many thanks,
Arna
タグ(2)
850件の閲覧回数
driesmoors
How to use the higher-level abstractions (the 'mods') is explained the Getting Started guide (UM_NHS31xx_GettingStarted.pdf), section 4.1.3 Mods. This file can be found in the SDK under the docs folder.
A small heads up: it looks like the trace module may be marked as 'obsolete' in a future SDK release. The uarttx module will be presented as an easier alternatie instead.
Kind regards,
Dries.
851件の閲覧回数
driesmoors
Kind regards,
Dries.
