How to get/read values of the current RF_DISCOVER_MAP on NFC Controllers?
limneos
I've been reading the documentation of NFC Controllers but I haven't found anywhere a command to read the currently assigned RF_DISCOVER_MAP (i.e. from the last RF_DISCOVER_MAP_CMD sent).
I understand that the discover_map values are saved somewhere.
What command reads the values, instead of setting them?
Asking in general, regarding NFC Controller Interface, not for a particular controller.
Thank you in advance.
jimmychan
