How to Set and Remove Password on NTAG213 Using PN532
EkoWaeS
Hello, I'm trying to set and remove passwords on NTAG213 tags using a PN532 module with an ESP8266 D1 Mini over I2C. I want to achieve the same functionality as the "Set Password" and "Remove Password" features in the NFC Tools app. I've tried multiple approaches, but none have worked successfully. Could you provide a detailed explanation of the correct command sequence, required libraries, and implementation steps?
Fabian_R
Hello sir,
Thank you for your interest in our products
I have to say that, PN532 isn't recommended anymore, is a very old product and it may have supply issues in the near future. We highly recommend migrating to PN7160 which is our latest product. Our recommended reader, use Libraries or APIs to speed up the development process.
Please let me know if there is any question regarding PN7160 I'll be happy to help.
In case you are still interested in using PN532 and ESP8266 I believe you will have to use the Datasheet's commands and registers for interfacing with NTAG 213.
Fabian
