How do I read/write Mifare Plus SL3 Card with CLRC663?
已解决
跳至解决方案
5,752 次查看
j_wang
I want to develop a Mifare Plus Card(all security level) Reader with the CLRC663, but I can only realize reading/writing Mifare Classic Card(= Mifare Plus Security Level 1).
I know the main difference between Mifare Classic Card and Mifare Plus Card SL3 is the step of Authentication and I found that CLRC663 datasheet doesn't show how to Authenticate Mifare Plus SL3.
I really need some help...
Please provide any tips or share your experience...
Thank you so much.
标签 (1)
标记 (1)
1 解答
4,943 次查看
stephanie_m
As you might know,  there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) and placed in DocStore, could you please follow this guides?
Docstore tutorial part 1: User Registration|NXP
Docstore tutorial part 2: portal usage|NXP
Also, you will need to contact one of our distributors available in the  Distributor Network|NXP to help you through the NDA process.
Estephania
在原帖中查看解决方案
2 回复数
4,944 次查看
stephanie_m
Estephania
4,943 次查看
j_wang
Thanks for answering my problem, Estephania.
Maybe I should pay more time to communicate with the distributor I know.
