HF TAG solution
HF TAG solution
jyothikurma
what is the write range for ICODE DNA HF tag IC? Is it same as read range?
Jonathan_Iglesias
Dear Jyothi Kurma,  the ICODE DNA IC can be operated without line of sight up to a distance of 1.5 m (gate width).
please check the data sheet https://www.nxp.com/docs/en/data-sheet/SL2S6002_SDS.pdf  section 1.1. and it should be the same read and write distance.
Jonathan
