GKI_getbuf() unable to allocate buffer!!!!
1,808 次查看
Felix-88
Hi Team,
I used the PN557 NFC chip to conduct cards reading stress test on Android 8.0.
After a period of time, the NFC process was stuck and could not read any cards.
Check the log prompts as follows.
02-15 08:47:51.542160 9416 9443 E BrcmNfcNfa: GKI_getbuf() unable to allocate buffer!!!!!
02-15 08:47:51.542249 9416 9443 E BrcmNfcNfa: nfc_main_hal_data_cback (): No buffer
How can I solve this problem?
Felix
标记 (1)
1,777 次查看
Fabian_R
Hello sir,
My apologies for the late response, at first glance I cannot provide any recommendation without more information. Could you please provide more information regarding your configuration? Also, we would recommend evaluating the possibility of using PN7150 for better hardware support.
Which Host device are you using?
Also, it would be very helpful if you could please let me know if you are using our latest NFC stack. Finally, could you please show us the full log?
Thank you for addressing us.
Fabian
