Firmware for the CLEV6630B
1,677 次查看
simonegoretti
Hello, I am looking for the original project that ships installed on the NXP CLEV6630B V2.0 Customer evaluation board.  AN11022 Section “3.1 LPC Firmware and Driver”  references that AN11021 has information on how to restore the software that came with the development board however the most up to date version of AN11021 is  Oct. 2012.  Which has no information on how to reload the software on the development board.
Simone
1 回复
1,472 次查看
robertoparamo
Hi Simone,
You have several firmware files within the Cockpit directory (browse to the specific installation folder in your system).
There is a folder called "firmware". I guess you can find your particular file based on your specific tool.
Once you know where is your file, you can flash it into your device using LPCXpresso and JTAG connector.
I followed these steps and I could use the Cockpit GUI again as before.
Good luck!
Roberto
