Emulate two MIFARE Cards on SmartMX
6,215 次查看
nc
Reading "SmartMX2 family P60D145y VB" data sheet I came across this line about MIFARE FleX:
" For optimum convergence solutions both MIFARE Plus (alternatively also MIFARE Classic as a subset) and MIFARE DESFire EV1 can be combined with the same customer OS "
Doe's this mean SmartMX2 can simulate both MIFARE Plus and DESFire EV1 together ?
I also have another question about SmartMX:
Let's say SmartMX emulates Mifare Plus. Because it's emulated tag that actually resides in memory under control of card operating system is it possible to format the tag even if some sectors are blocked ?
标记 (1)
5 回复数
5,633 次查看
Kan_Li
Hi Nika,
Please kindly refer to the following for details.
Yes, SMX2 can have both of them together.
Yes, you may reset sectors to default values, please see the firmware spec document for how to do it.
Hope that helps,
Kan
5,633 次查看
nc
Thanks for the reply,
Can you tell me which firmware spec and where in it can we find about resetting sectors ?
5,628 次查看
Kan_Li
Hi Nika,
The firmware spec documentation is available in the docstore, and you have to sign NDA at first and register an account to download it. Please contact your local DFAE to help with the NDA. Please kindly refer to Distributor Network|NXP for details.
I also attached the docstore user guide here.
Hope that helps,
Kan
5,628 次查看
nc
Hi Kan,
We have already signed the DNA and have access to docstore.
There are quite many specifications in there, I am interested in which document and where are those features written in detail so that we can implement it.
Nika
5,628 次查看
Kan_Li
Hi Nika,
You may refer to the following doc and search “Desfire” in the document to find the related information.
Hope that helps,
Kan
