Manufacturers would like to place NXP's NFC tags on metal foils that are sealed by the Induction heating equipment from vendors like Enercon Industries (https://www.enerconind.com/index.aspx). This equipment generates a strong time-varying magnetic field that generates eddy currents on the foil located inside the container and placed near its rim. Have anyone measured the strength of the field? I am finding out that HF RFID-NFC tags degrade in performance (even stop performing) when the voltage induced in the antenna coil during induction heating may exceed the safe working voltage limit of the tag's chip.
Have any of you observed this? any solution?
Hello sir,
Thank you for submitting your question to our community. Unfortunately, we don't have any inputs to provide to this issue. Since our scope is to only offer the ICs for creating final solutions, we don't have any studies that may give a recommendation for this type of issue. Unfortunately, we will have to recommend to please explore our partner's directory for RFID solutions and contact them directly in order to find an end product that might fill your needs.
