Datasheet for nxp nq330 NFC chipset
1,946 次查看
phodina
I'd like to ask for datasheet and other documents regarding the NXP nq330 chip.
Is there a driver available for Linux or userspace library that supports this chip?
I've found https://github.com/NXPNFCLinux/nxpnfc. Is it the right one?
Also if that would be the case why isn't it upstreamed into Linux kernel?
What is the address of that device? Is it possible to change it through some pull-ups or pull-downs?
What are the differences between pn547c2/pn548c2/pn533/pn65t/pn66t/pn80t/nq210/nq220/nq310/nq330?
Thank you
1 回复
1,930 次查看
KaiLi
Hello @phodina
Thanks for contacting us and interested in the NXP products. Based on your description, all of the product series what you mentioned, only PN533 is a mass production, and the others are customer specific products. So, we here have any material or documents.
To get related document of customer specific parts, please try to contact local NXP sales/FAE/Marketing team. They should be able to provide these. Anyway, if you want to be interesting in pn533, please let me know, I'll indicate you find related documents.
To update this case, you may reply by email.
To provide confidential information or attachments, you may add that online.
Please login to our NXP technical support portal:
https://support.nxp.com/s/case/5002p00002qYgHaAAK
The portal allows access to the full details of the case, including the previous communication.
Thank you for your interest in NXP Semiconductor products and for the opportunity to serve you.
Kelly
Technical Support
NXP Semiconductor
