CLRC663 field strength
1,832件の閲覧回数
lisong6080
      Hello!
                I want to do a contactless reader  by clrc663,but I need the antennas filed strength   adjustable while range from 1.5A/m to 7.5A/m. Can you give me some advise to achieve this function?
                     Thank you very much!
1,561件の閲覧回数
weidong_sun
1.5A/m to 7.5A/m is required in ISO specification, filed strength is only related to antenna, not NFC Chip. You needs to debug antenna to get the range.
Weidong
