CLRC663 ISO 15693 inventory
3,562件の閲覧回数
martinpeevski
   Hello, I am developing RFID reader based on CLRC663. All I want to do is continuously searching for a ISO15693 tags in the antenna field. I can read the device registers through UART interface but can't understand from the device datasheet and the NXP NFC reader library how to perform the inventory process to get the tag UID.
   I found the RFID Discover lite but have not success communicating with the CLRC663 and the software. May be I will have success with the RFID Discover but still have not NDA to download it.
   Also, I try to download the program  PC-Serial RS232, but can't find it on the internet.
   Can you give me some help to understand how to make simple ISO 15693 inventory to read the tags?
   Thank you in advance.
2,603件の閲覧回数
weidong_sun
Hello Martin,
   See following, please!
(1)CLRC663, MFRC631, MFRC630, SLRC610 PC-Serial RS232 Quick Start Guide(AN11505.pdf)
(2)PC serial SoftWare:
High-performance multi-protocol NFC frontend|NXP
(3) Other documents and Application Note
In addtion, you don't need to sign NDA, only need to register an account on website, then log in , you will be able to download them!
Weidong
