CLEV6630B Question
CLEV6630B Question
1,539件の閲覧回数
chailiming
I purchased a CLEV6630B test board on the NXP official website. I need to consult with some questions regarding the use of this card reader:
1. Can the CLEV6630B test board support the writing and reading of tags under the NFC cockpit platform?
It is currently possible to read the block content of the tag, but the writing is not successful.
2. Can the data for reading/writing be the language we normally use?
At present, the tag data I read out is hexadecimal encoding, do I need a decoding process?
3. Is there a detailed instruction manual for the NFC cockpit? Because some settings are not clear how to set?
4. We have static data and dynamic data for the data written by the tag. I would like to ask if there is any setting item to set the data state of the block storage? To prevent static data from being tampered with or erased
1,529件の閲覧回数
stephanie_m
You can check this quick video tutorial
https://www.nxp.com/video/quick-start-with-nfc-cockpit:QUICK-START-NFC-COCKPIT
As well as this quickstart guide .
https://www.nxp.com/products/rfid-nfc/nfc-hf/nfc-readers/nfc-cockpit-configuration-tool-for-nfc-ics:...
Hop this helps,
Estephania
