About NFC discovery loop time
2,565件の閲覧回数
zhlcui
hi , I using 6632 to read NTAG 213 tag, software using the nfc lib from nxp. And I find that the discovery time is about 600 mS. And I want to know if this situations is right. How can I speed up this time.NFC
タグ(1)
2,245件の閲覧回数
IvanRuiz
If you expect a better performance, it is better that you configure the Discovery Loop in the most optimal way according to the technologies that you require to be detected. It would be helpful to refer to the following link for a clear explanation of the Discovery Loop settings:
https://www.themobileknowledge.com/wp-content/uploads/2017/05/NFC-Reader-Library.pdf
Ivan.
