UUU with iMX95
UUU with iMX95
336件の閲覧回数
stoeanifm
I want to download and run U-Boot on a iMX95 based system.
I created this script cmd.lst:
SDPS: boot -f flash.bin
SDPS: done
SDPV: delay 1000
SDPV: write -f flash.bin -skipspl
SDPV: jump
SDPV: done
If I follow this commands step by step on command line it works fine.
But if I call
=> sudo /usr/bin/uuu -v -b ./cmd.lst
it hangs
Wait for Known USB Device Appear...
New USB Device Attached at 1:41-636B3EF4AB264648
1:41-636B3EF4AB264648>Start Cmd:SDPS: boot -f flash.bin
100%1:41-636B3EF4AB264648>Okay (3.007s)
1:41-636B3EF4AB264648>Start Cmd:SDPS: done
1:41-636B3EF4AB264648>Okay (0s)
Is it not allowed to do this steps within one command list?
Or what is wrong with this command list?
2 返答(返信)
313件の閲覧回数
yipingwang
Yes, SDPS and SDPV steps can be in one UUU command list. For i.MX95 the intended sequence is: first SDPS: boot -f flash.bin starts SPL, then SDPV: write -f flash.bin -skipspl and SDPV: jump complete/start U-Boot . The script examples I found use the same combined SDPS→SDPV flow without an SDPS: done between them .
What is wrong in your case is most likely the done placement, and possibly the way you invoke the script:
uuu_version 1.5.233
SDPV: delay 1000
SDPV: jump
Run it as a custom script file directly:
sudo /usr/bin/uuu -v ./cmd.lst
not as:
The -b option is documented for UUU built-in scripts such as sd , emmc , sd_all , or emmc_all , while a custom script file is normally passed directly to uuu . Also, done is described as the last command for the whole flow, so putting SDPS: done immediately after the first boot stage can make UUU stop that stage and wait for the next known USB device instead of continuing cleanly into the SDPV stage .
So I would change your file from:
SDPS: done
SDPV: delay 1000
SDPV: jump
SDPV: done
to:
uuu_version 1.5.233
SDPV: delay 1000
SDPV: jump
If it still waits at the SDPS→SDPV transition, try a newer UUU release; one i.MX95 report specifically recommends moving from uuu_1.5.201 to uuu_1.5.233 for hangs at 100% . You can also increase the stage-switch wait timeout with -T , which is the timeout for waiting for the next known USB device at a stage switch .
Use one script, but remove the intermediate done lines and run the file directly with uuu -v ./cmd.lst ; then update UUU or increase -T only if the board still does not re-enumerate into the SDPV stage.
292件の閲覧回数
stoeanifm
Hi and thank you@yipingwang
Please excuse the late feedback....
When I changed the cmd-lst to:
SDPV: delay 1000
SDPV: jump
SDPV: done
and then switched to uuu_1.5.233 it worked fine.
But the call must be:
=> ./uuu -v -b ./cmd.lst
With
=> ./uuu -v ./cmd.lst
it seems uuu try to load the cmd.lst as a botloader binary.
It returns:
New USB Device Attached at 3:5-636B3EF4AB264648
3:5-636B3EF4AB264648>Start Cmd:SDPS: boot -f "./cmd.lst"
%3CLINGO-SUB%20id%3D%22lingo-sub-2408167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EiMX95%E6%90%AD%E8%BC%89%E3%81%AEUUU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%20iMX95%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%ABU-Boot%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%9F%E3%81%84%E3%80%82%3CBR%20%2F%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20cmd.lst%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20%23%20%E3%83%A4%E3%83%9F%E3%83%B3%E3%83%BB%E3%82%A2%E3%83%A1%E3%83%83%E3%82%AF%E3%82%B9%3CBR%20%2F%3ESDPS%3A%20boot%20-f%20flash.bin%3CBR%20%2F%3ESDPS%3A%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3ESDPV%3A%20%E9%81%85%E5%BB%B6%201000%3CBR%20%2F%3E%20SDPV%3A%20write%20-f%20flash.bin%20-skipspl%3CBR%20%2F%3E%20SDPV%3A%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3CBR%20%2F%3ESDPV%3A%20%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%23%20%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%A9%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E6%89%8B%E9%A0%86%E9%80%9A%E3%82%8A%E3%81%AB%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8C%E3%81%B0%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%A7%E3%82%82%E7%A7%81%E3%81%8C%E9%9B%BB%E8%A9%B1%E3%81%97%E3%81%9F%E3%82%89%3CBR%20%2F%3E%3D%26gt%3B%20sudo%20%2Fusr%2Fbin%2Fuuu%20-v%20-b%20.%2Fcmd.lst%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%82%8C%E3%81%AF%E3%81%B6%E3%82%89%E4%B8%8B%E3%81%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%3C%2FP%3E%3CP%3E%E6%97%A2%E7%9F%A5%E3%81%AEUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%82%8B%E3%81%BE%E3%81%A7%E3%81%8A%E5%BE%85%E3%81%A1%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84...%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C1%3A41-636B3EF4AB264648%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E1%3A41-636B3EF4AB264648%26gt%3B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E9%96%8B%E5%A7%8B%3ASDPS%3A%20boot%20-f%20flash.bin%3CBR%20%2F%3E100%251%3A41-636B3EF4AB264648%26gt%3BOK%20(3.007%E7%A7%92)%3CBR%20%2F%3E%201%3A41-636B3EF4AB264648%26gt%3B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E9%96%8B%E5%A7%8B%3ASDPS%3A%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E1%3A41-636B3EF4AB264648%26gt%3BOK%20(0%E7%A7%92)%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%921%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%AA%E3%82%B9%E3%83%88%E5%86%85%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E8%A8%B1%E5%8F%AF%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%82%E3%82%8B%E3%81%84%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AE%E3%81%A9%E3%81%93%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UUU%20with%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408317%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81SDPS%E3%81%A8SDPV%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%AF1%E3%81%A4%E3%81%AEUUU%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%83%AA%E3%82%B9%E3%83%88%E3%81%AB%E3%81%BE%E3%81%A8%E3%82%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82i.MX95%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%84%8F%E5%9B%B3%E3%81%95%E3%82%8C%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%E3%81%BE%E3%81%9ASDPS%3A%20boot%20-f%20flash.binSPL%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%80%81%E6%AC%A1%E3%81%AB%20SDPV%3A%20write%20-f%20flash.bin%20-skipspl%20%E3%81%8A%E3%82%88%E3%81%B3%20SDPV%3A%20jump%20complete%2Fstart%20U-Boot%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E7%A7%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%9F%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E4%BE%8B%E3%81%A7%E3%81%AF%E3%80%81SDPS%3A%20done%20%E3%82%92%E6%8C%9F%E3%81%BE%E3%81%9A%E3%81%AB%E3%80%81%E5%90%8C%E3%81%98%E7%B5%90%E5%90%88%E3%81%95%E3%82%8C%E3%81%9F%20SDPS%E2%86%92SDPV%20%E3%83%95%E3%83%AD%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%A0%B4%E5%90%88%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AF%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E8%A8%AD%E7%BD%AE%E6%96%B9%E6%B3%95%E3%81%A8%E3%80%81%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AE%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E6%96%B9%E3%81%AB%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E9%AB%98%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Euuu_version%201.5.233%3C%2FP%3E%0A%3CP%3ESDPS%3A%20boot%20-f%20flash.bin%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E9%81%85%E5%BB%B6%201000%3C%2FP%3E%0A%3CP%3ESDPV%3A%20write%20-f%20flash.bin%20-skipspl%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3C%2FP%3E%0A%3CP%3E%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E7%9B%B4%E6%8E%A5%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%EF%BC%9A%3C%2FP%3E%0A%3CP%3Esudo%20%2Fusr%2Fbin%2Fuuu%20-v%20.%2Fcmd.lst%3C%2FP%3E%0A%3CP%3E%E3%81%A8%E3%81%97%E3%81%A6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%3A%3C%2FP%3E%0A%3CP%3Esudo%20%2Fusr%2Fbin%2Fuuu%20-v%20-b%20.%2Fcmd.lst%3C%2FP%3E%0A%3CP%3E-b%20%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AF%E3%80%81sd%E3%80%81emmc%E3%80%81sd_all%E3%80%81emmc_all%20%E3%81%AA%E3%81%A9%E3%81%AE%20UUU%20%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BF%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E6%96%87%E6%9B%B8%E5%8C%96%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81uuu%20%E3%81%AB%E7%9B%B4%E6%8E%A5%E6%B8%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%80%8Cdone%E3%80%8D%E3%81%AF%E5%85%A8%E4%BD%93%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E3%81%AE%E6%9C%80%E5%BE%8C%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E3%81%97%E3%81%A6%E8%AA%AC%E6%98%8E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E3%83%96%E3%83%BC%E3%83%88%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AE%E7%9B%B4%E5%BE%8C%E3%81%ABSDPS%3A%20done%E3%82%92%E5%85%A5%E3%82%8C%E3%82%8B%E3%81%A8%E3%80%81UUU%E3%81%8C%E3%81%9D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81SDPV%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E3%82%B9%E3%83%A0%E3%83%BC%E3%82%BA%E3%81%AB%E9%80%B2%E3%82%80%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E6%AC%A1%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AEUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%BE%85%E3%81%A4%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E3%81%BB%E3%81%86%E3%81%8C%E3%81%84%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%0A%3CP%3ESDPS%3A%20boot%20-f%20flash.bin%3C%2FP%3E%0A%3CP%3ESDPS%3A%20%E5%AE%8C%E4%BA%86%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E9%81%85%E5%BB%B6%201000%3C%2FP%3E%0A%3CP%3ESDPV%3A%20write%20-f%20flash.bin%20-skipspl%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E5%AE%8C%E4%BA%86%3C%2FP%3E%0A%3CP%3E%E3%80%81%3C%2FP%3E%0A%3CP%3Euuu_version%201.5.233%3C%2FP%3E%0A%3CP%3ESDPS%3A%20boot%20-f%20flash.bin%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E9%81%85%E5%BB%B6%201000%3C%2FP%3E%0A%3CP%3ESDPV%3A%20write%20-f%20flash.bin%20-skipspl%3C%2FP%3E%0A%3CP%3ESDPV%3A%20%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3C%2FP%3E%0A%3CP%3ESDPS%E2%86%92SDPV%E9%81%B7%E7%A7%BB%E3%81%A7%E3%81%BE%E3%81%A0%E5%BE%85%E6%A9%9F%E7%8A%B6%E6%85%8B%E3%81%8C%E7%B6%9A%E3%81%8F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%82%88%E3%82%8A%E6%96%B0%E3%81%97%E3%81%84UUU%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82i.MX95%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE1%E3%81%A4%E3%81%A7%E3%81%AF%E3%80%81100%25%E3%81%A7%E3%83%8F%E3%83%B3%E3%82%B0%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%ABuuu_1.5.201%E3%81%8B%E3%82%89uuu_1.5.233%E3%81%AB%E7%A7%BB%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%89%B9%E3%81%AB%E6%8E%A8%E5%A5%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81-T%E3%81%A7%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%AE%E5%BE%85%E6%A9%9F%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%82%92%E5%A2%97%E3%82%84%E3%81%99%E3%81%93%E3%81%A8%E3%82%82%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82-T%E3%81%AF%E3%80%81%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E6%AC%A1%E3%81%AE%E6%97%A2%E7%9F%A5%E3%81%AEUSB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%92%E5%BE%85%E3%81%A4%E3%81%9F%E3%82%81%E3%81%AE%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E1%20%E3%81%A4%E3%81%AE%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E4%B8%AD%E9%96%93%E3%81%AE%20done%20%E8%A1%8C%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%80%81uuu%20-v%20.%2Fcmd.lst%20%E3%81%A7%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%9B%B4%E6%8E%A5%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%81%8C%E3%81%BE%E3%81%A0%20SDPV%20%E3%82%B9%E3%83%86%E3%83%BC%E3%82%B8%E3%81%AB%E5%86%8D%E5%88%97%E6%8C%99%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AB%E3%81%AE%E3%81%BF%E3%80%81UUU%20%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%99%E3%82%8B%E3%81%8B%E3%80%81-T%20%E3%82%92%E5%A2%97%E3%82%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2409190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20UUU%20with%20iMX95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2409190%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%E3%80%81%40yipingwang%3C%2FA%3E%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%89%E3%83%90%E3%83%83%E3%82%AF%E3%81%8C%E9%81%85%E3%81%8F%E3%81%AA%E3%82%8A%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20cmd-lst%20%E3%82%92%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20SDPS%3A%20boot%20-f%20flash.bin%3CBR%20%2F%3ESDPV%3A%E3%83%87%E3%82%A3%E3%83%AC%E3%82%A41000%3CBR%20%2F%3ESDPV%3A%20write%20-f%20flash.bin%20-skipspl%3CBR%20%2F%3ESDPV%3A%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3CBR%20%2F%3ESDPV%3A%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81uuu_1.5.233%E3%81%AB%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%81%9F%E3%82%89%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E5%91%BC%E3%81%B3%E3%81%8B%E3%81%91%E3%81%AF%E3%81%93%E3%81%86%E3%81%A7%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%80%82%3CBR%20%2F%3E%20%3D%26gt%3B%20.%2Fuuu-v%20-b%20.%2Fcmd.lst%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%A8%3CBR%20%2F%3E%3D%26gt%3B%20.%2Fuuu-v%20.%2Fcmd.lst%3CBR%20%2F%3E%E3%81%A9%E3%81%86%E3%82%84%E3%82%89%E3%80%81cmd.lst%20%E3%82%92%E3%83%9C%E3%83%83%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%81%A8%E3%81%97%E3%81%A6%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E8%BF%94%E3%81%95%E3%82%8C%E3%82%8B%E5%80%A4%EF%BC%9A%3CBR%20%2F%3E%E6%96%B0%E3%81%97%E3%81%84USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%8C3%3A5-636B3EF4AB264648%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E3%3A5-636B3EF4AB264648%26gt%3B%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E9%96%8B%E5%A7%8B%3ASDPS%3A%20boot%20-f%20%22.%2Fcmd.lst%22%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
