TEA1795T
TEA1795T
2,399件の閲覧回数
牧童都市
你好:
请问,我手上的TEA1795T的2脚(地)和3脚(驱动A)和6脚(驱动B)互导通,3脚和6脚对2脚阻值2欧姆,开始用万用表测试时,有10K欧姆,但是,多测几遍,就导通了。
タグ(1)
2 返答(返信)
2,172件の閲覧回数
guoweisun
Thanks for your interesting in NXP products.
Some questions for you:
1: Does this your tested device  work normally in your actual circuit?
2: If you change the device and the test equipment, can the test result be reappear?
2,172件の閲覧回数
牧童都市
你好,谢谢
我暂时没有新的TEA1795T.
