Looking for expert support on UPS Design
6,578 次查看
Kuldeep_EIC
Hi, I am designing a UPS type of supply system. Below are some input parameters while design:
- Input voltage to charge Battery --> Single Phase input ~ 110V (10% tolerance)
- Battery capacity --> 5000 WHr.
- Invertor capacity --> 7500W.
- Output Voltage --> 240V
Please suggest if any reference design available or off the self module available.
6 回复数
6,440 次查看
Kuldeep_EIC
Hi, Thanks for sharing technical reference document.
Is there any reference NXP's modular based design available for Battery charger application.
Input: 110V@16-20A
Output: 40-60V with 2.2kW output power to charge Li-ion Battery.
6,358 次查看
xiangjun_rong
This is the website of Li-ion battery charging solution, pls refer to it:
https://www.nxp.com/products/power-management/battery-management:BATTMNGT
Hope it can help you
XiangJun Rong
6,294 次查看
Kuldeep_EIC
Hi, Thanks for sharing link for reference design.
I have not found any solution as per my requirement for high power battery charging application. Does NXP have high battery charging solution available, if yes please suggest.
6,230 次查看
xiangjun_rong
Pls refer to the EV charging solution:
https://www.nxp.com/applications/automotive/electrification-and-powertrain/ev-charging-station:EV-CH...
Hope it is helpful
XiangJun Rong
6,544 次查看
xiangjun_rong
Long time ago, we developed the UPS application, this is the application note DRM064.pdf, hope it can help you
I suppose the UPS application has not updated for a long time.
Xiangjun Rong
6,541 次查看
xiangjun_rong
This is another UPS solution based on DSC
XiangJun Rong
