AN3943 fixed point
AN3943 fixed point
garimella
I was referring to AN3943 and would like to know further as how to implement the algorithm in fixed point
I have some idea going through the app note. Please confirm if the following information is correct
1. Input signals, sine/cosine: 24 bit fractional format: Q23
2. Coefficients K1d and K2d are 24 bit fractional format : Q23
3. sine/cosine functions(feedback element): not sure: may be Q23 (pl. confirm)
garimella
Could you share simulink or matlab file which could be simulated?. I Tried to create this model in simulink by providing similar dataypes as mentioned above, but output is unstable.
PetrS
for Matlab/Simulink question please post it on https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/bd-p/mbdt
BR, Petr
PetrS
I can see this from the AN
1)
2)
3) this will probably be internal for ATO, should be 24bit frac too.
BR, Petr
