where is 'SCB_SCR' ?
3,043件の閲覧回数
dearwww2000
Hi ,
Can't found 'SCB_SCR'  in <S32K-RM.pdf>.
Who can give help ?
in S32DS, you can configure 'Sleep on Exit Value' with 'power_manager' component.
2,944件の閲覧回数
constantinrazva
Hello dearwww2000‌,
SCB stands for System Control Block and it usually provides system implementation information + system control. One of the SCB registers is SCR - System Control Register. This controls low power state features (for entry and exit). It is part of the ARM core, so that is why you do not find it in the Reference Manual for the S32K -- you can find more information over ARM infocenter. You can check out this pdf file -- chapter 4.3.6 covers the SCR.
Hope this helps,
Razvan.
2,944件の閲覧回数
constantinrazva
You can ask in the https://community.nxp.com/community/s32/s32k  community -- there you should find more help on matters like this -- we mostly handle MATLAB/Simulink questions here.
Kind regards,
Razvan.
