Unable to suspend the project or set a breakpoint
XH
Hi @FlorinCiuca ,
I hope you are well. I have encountered a problem. When I export a simple Dio(one LED to toggle) project from MBDT and imported the code into S32DS. When the project is running, I could not suspend it or set a breakpoint to debug the code. Do you know what causes this and how to solve it? Attached are the error msg when I tried to suspend or set a break point to the running project. ( saying interrupt failed, or breakpoint installation failed) Many thanks, from Xiaomei
