Single shunt current sensing using MBDT / S12ZVM
3,101件の閲覧回数
Stefan_9811
Hi everybody,
I purchased the S12ZVM High Current Evaluation Board (MCSXSR1CS12ZVM) and want to develop a sensorless FOC using the model based desing toolbox (MBDT).
In the MBDT Library for S12ZVM an FOC example is provided, which uses a dual shunt current measurement. As the MCSXSR1CS12ZVM board has just a single shunt resistor available I am seeking for some example, how to implement a single shunt current measurement for the board with MBDT.
I would really appreciate your help.
Kind regards,
Stefan
2 返答(返信)
3,073件の閲覧回数
lama
AN5327
Ladislav
3,061件の閲覧回数
Stefan_9811
Hi Ladislav,
thank you very much for your reply and the documents.
I see that you send me a Code Warrior project in C. Is it also possible to get a Simulink model, which implements the singel shunt current sensing on the "MCSXSR1CS12ZVM" Board?
Kind regards,
Stefan
