S32K344 avoid FS26 PMIC keeping resetting MCU
HarryQi
Hi NXP,
Quoted from tutorial
'The FS26 onboard PMIC by default implements a challenger window watchdog that will reset the S32K344 MCU continuously if the challenge is not handled in software.
To avoid this, the FS26 must be put into debug mode. This is done manually by removing the JP1 and then supplying exactly 12.0V on P27 or P28 and then inserting the JP1 jumper.'
my problem is how to handle the FS26 onboard PMIC by default implements a challenger window watchdog in the software to avoid resetting MCU.
