S32K148EVB-Q176 code build problem
3,663件の閲覧回数
Buxa
Hello, I will try my first project in S32K148EVB-Q176 but I couldn't even start basic LED&Buttons example. I made configuration and code is building but there is no action on board. You can find all configurations as attachments. I'm looking forward to your help.
3,637件の閲覧回数
mariuslucianand
Hello @Buxa ,
The settings seem to be right. Can you please check on the board that one of the DS3 or DS2 is turned on? Can you please check the jumpers settings on the board to make sure that the MCU is powered on?
Hope this helps,
Marius
