Reference Models
Reference Models
mweiss
the readme.txt of the MBDT add on lists under known issues:
- using Model-Based Design Toolbox for S32K3 blocks in referenced models will cause the build to fail
How do these problems look like or how do we know a problem we experience is related to this issue?
Actually, we would like to use hierarchical decomposition into a layered architecture to design our projects model. Being able to split up into several files that follow this architecture ideally with a 1:1 mapping would be very helpful. If there are build issues with model references, will subsystem references work?
We are actually still Simulink beginners and there might be things we just don't know. We would really like to avoid putting everything into one slx file.
Are there any bigger real world examples to look at regarding architecture and layering?
Thank you
