RAM/FLASH ECC error FCCU Fault injection
2,735件の閲覧回数
akhil_kumar
How to inject RAM ECC NCF fault for FCCU?
is there any example available to create a RAM/FLASH ECC fault ?
Akhil
ラベル(2)
3 返答(返信)
2,557件の閲覧回数
akhil_kumar
Hi Razvan,
We can provide basic configuration understanding of FCCU driver.
Akhil
2,555件の閲覧回数
akhil_kumar
Hi Chivu,
Thanks for your reply
We are testing RAM ECC with our custom code,However still not able to insert fault at MEMU and FCCU level simultaneously.Hereby i am attaching sample code and dumped configuration for your reference.Please look into it for your reference and help us in this regards.
Akhil
2,555件の閲覧回数
constantinrazva
Unfortunately we do not have such an example as we do not have support for FCCU. The only way this would be possible is by inserting custom code into your model. If you want to go with this approach and are facing issues, please let us know. We can help on the MATLAB/Simulink side, but we do not have expertise on the FCCU driver side.
Kind regards,
Razvan.
