MPC5744P can rx_mask
260068845
I use MPC5744P to develop CAN bus communication. I want to receive the data of multi-frame ID on CAN by interrupt. The ID format is 0x03xx. The CAN setting is as follows, but I found that I can't receive the data. The whole process is in the attachment. I want to ask where is the problem?
260068845
Hello,constantinrazvan.chivu‌
   Could you find the error? Thanks!
Thanks with best regards
Huang
