MPC5744 CLOCK SETUP FAIL
669件の閲覧回数
acechongya
        I used mbd generate code, but startup fail.  cpu dead in function of CLOCK_DRV_Init .
my hardware is DEVKIT-MPC5744P. can you tell some reasons ?
status_t CLOCK_DRV_Init(clock_manager_user_config_t const * config)
    status_t result = STATUS_SUCCESS;
    DEV_ASSERT(config != NULL);
    /* Clears peripheral clock gating and all clock sources in all power modes.
     * Only an IRC type clock source is enabled and set as system clock source. */
    result = CLOCK_SYS_Reset();
    if (STATUS_SUCCESS == result)
        /* Configure clock sources. */
        result = CLOCK_SYS_ConfigureCgmcs(config);
            /* Configure peripheral clock gating, system clock source
             * and clock sources in all power modes. */
            result = CLOCK_SYS_ConfigureMcMe(config);
                /* Configure peripheral clocks. */
                result = CLOCK_SYS_ConfigureCgm(config);
#if FEATURE_HAS_SDPLL_CLK
                    result = CLOCK_SYS_ConfigureSdpll(config);
CLOCK_SYS_SetCMU(config);
#else
#endif
    /* Calculate frequencies of clock sources and cache these values. This function is not called at runtime */
    CLOCK_SYS_CalculateFrequenciesOfClockSources(false);
#if (defined(PRAMC_0) || defined(PRAMC_1) || defined(PRAMC_2))
    uint32_t systemFrequency = 0U;
    (void)CLOCK_DRV_GetFreq(SCS_CLK, &systemFrequency);
    if (systemFrequency >= FEATURE_FT_DIS_CHECK_SYSTEM_FREQUENCY)
#if defined(PRAMC_0)
PRAMC_EnableFlowThrough(PRAMC_0, false);
#endif
#if defined(PRAMC_1)
PRAMC_EnableFlowThrough(PRAMC_1, false);
#endif
#if defined(PRAMC_2)
PRAMC_EnableFlowThrough(PRAMC_2, false);
#endif
    else
PRAMC_EnableFlowThrough(PRAMC_0, true);
#endif
PRAMC_EnableFlowThrough(PRAMC_1, true);
#endif
PRAMC_EnableFlowThrough(PRAMC_2, true);
#endif
#endif
    return result;
タグ(1)
0 返答(返信)
%3CLINGO-SUB%20id%3D%22lingo-sub-2322840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5744%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E5%A4%B1%E6%95%97%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2322840%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Embd%20%E3%81%A7%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CSTRONG%3ECLOCK_DRV_Init%20%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%20CPU%20%E3%81%8C%E6%AD%BB%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%E7%A7%81%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AFDEVKIT-MPC5744P%E3%81%A7%E3%81%99%E3%80%82%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E7%90%86%E7%94%B1%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Estatus_t%20CLOCK_DRV_Init(clock_manager_user_config_t%20const%20*%20config)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3Estatus_t%20%E7%B5%90%E6%9E%9C%20%3D%20STATUS_SUCCESS%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3EDEV_ASSERT(%E6%A7%8B%E6%88%90%20!%3D%20NULL)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%A8%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E3%82%AF%E3%83%AA%E3%82%A2%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E*%20IRC%20%E3%82%BF%E3%82%A4%E3%83%97%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%BF%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%20%3D%20CLOCK_SYS_Reset()%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%20%3D%20CLOCK_SYS_ConfigureCgmcs(config)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%B2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%99%E3%82%8B%3C%2FDIV%3E%3CDIV%3E*%20%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E9%9B%BB%E6%BA%90%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%20%3D%20CLOCK_SYS_ConfigureMcMe(config)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%20%3D%20CLOCK_SYS_ConfigureCgm(config)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23FEATURE_HAS_SDPLL_CLK%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%7B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82*%2F%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%20%3D%20CLOCK_SYS_ConfigureSdpll(config)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECLOCK_SYS_SetCMU(%E8%A8%AD%E5%AE%9A)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%EF%BC%83%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3C%2FDIV%3E%3CDIV%3Eif%20(STATUS_SUCCESS%20%3D%3D%20%E7%B5%90%E6%9E%9C)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ECLOCK_SYS_SetCMU(%E8%A8%AD%E5%AE%9A)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%2F*%20%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%BD%E3%83%BC%E3%82%B9%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%E3%82%92%E8%A8%88%E7%AE%97%E3%81%97%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%80%A4%E3%82%92%E3%82%AD%E3%83%A3%E3%83%83%E3%82%B7%E3%83%A5%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AF%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AB%E3%81%AF%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%20*%2F%3C%2FDIV%3E%3CDIV%3ECLOCK_SYS_CalculateFrequenciesOfClockSources(false)%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%23if%20(%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF(PRAMC_0)%20%7C%7C%20%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF(PRAMC_1)%20%7C%7C%20%E5%AE%9A%E7%BE%A9%E6%B8%88%E3%81%BF(PRAMC_2))%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3Euint32_t%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%91%A8%E6%B3%A2%E6%95%B0%20%3D%200U%3B%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E(void)CLOCK_DRV_GetFreq(SCS_CLK%E3%80%81%26amp%3B%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%91%A8%E6%B3%A2%E6%95%B0)%3B%3C%2FDIV%3E%3CDIV%3E%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E5%91%A8%E6%B3%A2%E6%95%B0%20%26gt%3B%3D%20FEATURE_FT_DIS_CHECK_SYSTEM_FREQUENCY%20%E3%81%AE%E5%A0%B4%E5%90%88%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_0)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_0%E3%80%81false)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_1)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_1%E3%80%81false)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_2)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_2%E3%80%81false)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%E3%81%9D%E3%82%8C%E4%BB%A5%E5%A4%96%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%20%26nbsp%3B%20%7B%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_0)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_0%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_1)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_1%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%23%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88(PRAMC_2)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3EPRAMC_EnableFlowThrough(PRAMC_2%E3%80%81true)%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%26nbsp%3B%20%7D%3C%2FDIV%3E%3CDIV%3E%23endif%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E7%B5%90%E6%9E%9C%E3%82%92%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3CDIV%3E%7D%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
