MBDT adc block
MBDT adc block
avinashstarkenn
Programming s32k3 using MBDT
I am working on ADC block and for configuration i am not able to understand what are following points
1. Presampling
2. group access mode
3. AdcGroupConversion Confiuration in S32 configurator tools.
Any tutorial with explanation of configuration of ADC block is appreciated.
georgevictor
Hi, @avinashstarkenn,
The information about the ADC configuration is detailed in the RTD  documentation. The AUTOSAR documentation is the most comprehensive source if you want to learn more about the ADC functionalities and how to use them.
These documents can be easily found inside the ADC block help of our toolbox.
Cheers,
Victor
