MBDT Freemaster
MBDT Freemaster
avenkat
Unable to update the elf file with the embedded coder.
How do you add variables to freemaster if updating elf is not possible.
Irina_Costachescu
Hi @avenkat
Could you please check the following article, describing the MBDT integration with FreeMASTER and how such tool can be used for monitoring the variables of your application?
Let us know if it helps.
Irina
