LPUART1 rx problem
LPUART1 rx problem
1,458 次查看
623619261
   I have some questions about LPUART1 of 'S32K142'.I use it with LIN transceiver 'ATA663211'.
I  use it to be master.
My transmit function is right,but receive function is stranger.
When I want to receive data form slave,I transmit head first.Then I receive data.
I use code like this 'if(LPUART1->STS & rdrf mask) else if(LPUART1->STS & tc mask)' in the interrupt.
The problem is when I want to transmit data,the rdrf is '1',so it do the receive work.I don't know how rdrf to be '1'.
I clear it at first.
So I want to know whether other status would change the rdrf.
My English is very poor, forgive me.
标记 (1)
1,355 次查看
constantinrazva
Hello [email protected]‌,
On this community we handle questions regarding MATLAB/Simulink and our toolboxes. For a detailed answer for your question you should post it on https://community.nxp.com/community/s32/s32k community - there you'll get answers from SDK experts.
Hope this helps,
Razvan.
