I2C config
I2C config
saurabhkulkarni123
Hello NXP,
In my model, I'm using two I2C config block for a particular application, Now while I'm generating the code it show the error of redefinition of the LPI2C config function where I use two different I2C block,
SorinIBancila
Indeed there is a bug in the implementation of the LPI2C. Can you please download and install this hotfix and see if it solves the problem?
Bancila Sorin
