How to remove Freemaster from project.
1,316件の閲覧回数
Alfredo_Rubio
We are working in a project in which we are not using the Freemaster tool at all.
I have tried to remove the Fremaster Config block from the model, but then I got a lot of build errors. It seems that the makefile is trying to built or link the freemaster files.
gmake: *** [freemaster_appcmd.o] Error 1
gmake: *** Waiting for unfinished jobs....
gmake: *** [freemaster_pipes.o] Error 1
gmake: *** [freemaster_protocol.o] Error 1
gmake: *** [freemaster_rec.o] Error 1
gmake: *** [freemaster_s32k3xx_lpuart.o] Error 1
gmake: *** [freemaster_scope.o] Error 1
gmake: *** [freemaster_serial.o] Error 1
gmake: *** [freemaster_tsa.o] Error 1
gmake: *** [freemaster_ures.o] Error 1
gmake: *** [freemaster_utils.o] Error 1
Thanks you in advance
1,298件の閲覧回数
Irina_Costachescu
Hi @Alfredo_Rubio
Thank you for reaching out to us with respect to this issue. As we are aware of the behavior that you have encountered, and we will try to address it in our future release, could you please try, as a workaround, to remove the Config folder placed to the model, and then try and build it again?
Thank you,
Irina
