Gcc ignoring pragma statements to place code into ITCM memory.
已解决
跳至解决方案
677 次查看
RNJ
Hello!
Using Matlab R2025b, Simulink and MBDT for S32K3 version 1.7.1 here.
To optimize the performance of a motor controller application we are developing we want to place some parts of the code into the ITCM memory and later on, DTCM memory for data.
As for now, for testing the workflow, I am trying to get a function placed into ITCM memory. I managed to get Simulink/ embedded coder to place the correct pragma statements in to the c code like:
#pragma GCC section text ".itcm_text"
static void  Motor_Drive_Subsystem(void)
#pragma GCC section text ""
However, when compiling the application gcc ignore these pragma statements and places the code in the standard .text segment. This can be concluded with The objdump command:
arm-none-eabi-objdump -h Motor_Control.o      (beeing the .o file generated from the c-file containing the Motor_Drive_Subsystem function)
There are no .itcm_text in the list just .text.xxxx segments (among the other non text segments).
When compiling I use the standard switches for gcc set by the MBDT environment:
arm-none-eabi-gcc -O2 -c -std=c99 -fshort-enums -funsigned-char -fstack-usage -ffunction-sections -fdata-sections -g -pedantic -Wall -Wextra -fmessage-length=0 -funsigned-bitfields -fno-common -Wunused -Wstrict-prototypes -Wsign-compare -Werror=implicit-function-declaration -mcpu=cortex-m7 -mthumb -mlittle-endian -mfloat-abi=hard -mfpu=fpv5-sp-d16 -DD_CACHE_ENABLE -DI_CACHE_ENABLE -specs=nano.specs -specs=nosys.specs --sysroot="C:\MATLAB_Add-Ons\Toolboxes\NXP_MBDToolbox_S32K3\tools\build_tools\gcc_v10.2\gcc-10.2-arm32-eabi\arm-none-eabi\newlib" -DSTEP_GPT_TIMER -DSTEP_GPT_CHANNEL=GptConf_GptChannelConfiguration_StepTimer -DSTEP_GPT_CHANNEL_FREQ=40000000 -DSTEP_GPT_CHANNEL_VALUE_MAX=4294967295 -DAUTOSAR_OS_NOT_USED -D__MW_TARGET_USE_HARDWARE_RESOURCES_H__ -DGCC -DS32K3XX -DS32K396 -DCPU_S32K396 -DENABLE_FPU -DMPU_ENABLE -DMBDT_INIT -DCLASSIC_INTERFACE=0 -DALLOCATIONFCN=0 -DTERMFCN=0 -DONESTEPFCN=1 -DMAT_FILE=0 -DMULTI_INSTANCE_CODE=0 -DINTEGER_CODE=0 -DMT=0  -DTID01EQ=0 -DSTACK_SIZE=64 -DRT -DMODEL=Motor_Control -DNUMST=1 -DNCSTATES=0 -DHAVESTDIO -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0 -IC: .....
By modifying the generated c code file and manually compiling it I can conclude the following:
Removing the “static” declaration of the function does not help. However, removing “static” and using the alternative way for this by adding an attribute statement on the function:
static void  __attribute__((section(".itcm_text")))Motor_Drive_Subsystem(void);
will create a .itcm_text segment in the .o file.
I am not sure if I am doing something wrong here or if it is a tool problem.
Can someone guide me on how to get this working?
Of course, we want the tool chain to handle this and do not want to manually modify the c code after code generation.
As far as I can see it looks like the startup_cm7.s and linker_flash_s32k396.ld files are prepared for handling the ITCM and DTCM memories.
I found this post in the forum, not sure if it is relevant for this: https://community.nxp.com/t5/S32-Design-Studio/No-GCC-11-4-item-in-new-project-wizard-dialog-on-S32D...
The MBDT gcc seems to be build 1728 where as the fixed one in the post is build 1803.
Thanks in advance!
1 解答
575 次查看
SorinIBancila
I am glad that you were able to solve the problem!
Sorin Bancila
在原帖中查看解决方案
5 回复数
615 次查看
RNJ
Hi Sorin
Thanks for helping out!
I was actually following those instructions at Mathworks web site.
Now I have the insertion of attribute statements instead of pragma statements working.
But still, gcc refuses to put the function into the .itcm_text segment.
I use these code generation settings for the block:
Generated code for function like this:
/* Redirect standard code generation to ITCM */
Conclusion:
  • No itcm_text segment in .o file
  • Gcc optimizes the function away completely (seen by disassembling .o file)
  • If I remove the “static” declaration of the function in the generated .c and manually recompile it I will get the .itcm_text segment in the .o file.
  • It looks like the “static” declaration makes the gcc compiler ignore the attribute prefix.
If I set the block to “Reusable function” in modelsim, hoping this would remove the static declaration:
I get:
  • Still no .itcm_text segment in .o file
  • Function still declared as “static” in generated c code
  • Disassembly of .o file shows that gcc keeps the function in the assembly code but there is no sign of directing to .itcm_text segment
So is the “static” declaration the problem (something with settings in Simulink or embedded coder) or is the problem with gcc prioritizing “static” over the “attribute” declaration?
588 次查看
SorinIBancila
I tried to reproduce the problem you encounter, the function generated do not include the 'static' keyword.
What I did to test was to load a basic example (s32k3xx_dio_s32ct) and move all the blocks in a subsystem and configure it to be atomic and to use the MemSection_ITCM definitions. Can you try to do the same? If it doesn't reproduce in this scenario, maybe there are some setting in your model that force the generated function to be static.
Sorin Bancila
579 次查看
RNJ
Aha!
Nowing that the "static" declaration is reason for my problems I had a look at the code generation section in configuration parameters and found this:
Unticking it solved the problem!
No static declaration of the function(s) and I can see the itcm_text segment in the mapping file. I you also think this is the solution I am sattisfied.
Thanks for the help, much appreciated!
576 次查看
SorinIBancila
Sorin Bancila
647 次查看
SorinIBancila
Please check the following page on MathWorks website how to set up a custom storage class.: Control Data and Function Placement in Memory by Inserting Pragmas.
The part that you need to use is "Override Default Memory Placement for Subsystem Functions and Data".
After you created you custom storage class, you must configure the model to load it:
0. Create and configure the custom storage class:
1. Enter Code Perspective
2. Open Embedded Coder DIctionary (Model)
3. Load the custom class you previously created.
4. Inside the model, create a new Subsystem and set it to atomic.
5.  Inside the Code Generation, set the Memory section for execution functions: "MemSection_ITCM" as set in the custom class.
6.  arm-none-eabi-objdump properly repots that ITCM_ToggleDIO.o is loaded into the .itcm_text memory section
arm-none-eabi-nm -n s32k3xx_dio_s32ct.elf also says that ITCM_ToggleDIO is found at  0x0 address.
If the .elf is flashed from the S32DS and a breakpoint is used inside the s32k3xx_dio_s32c_ITCM_ToggleDIO function., in the disassembly view we can see that the instructions are stored starting at 0x0 address.
Sorin Bancila
%3CLINGO-SUB%20id%3D%22lingo-sub-2404463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGcc%20%E5%BF%BD%E7%95%A5%20pragma%20%E8%AF%AD%E5%8F%A5%EF%BC%8C%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%85%A5%20ITCM%20%E5%86%85%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%81%3C%2FP%3E%3CP%3E%E8%BF%99%E9%87%8C%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20Matlab%20R2025b%E3%80%81Simulink%20%E5%92%8C%20MBDT%20for%20S32K3%20%E7%89%88%E6%9C%AC%201.7.1%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%BA%E4%BA%86%E4%BC%98%E5%8C%96%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%BC%80%E5%8F%91%E7%9A%84%E7%94%B5%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%80%A7%E8%83%BD%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%B0%86%E9%83%A8%E5%88%86%E4%BB%A3%E7%A0%81%E6%94%BE%E5%85%A5%20ITCM%20%E5%86%85%E5%AD%98%E4%B8%AD%EF%BC%8C%E7%A8%8D%E5%90%8E%E5%B0%86%E6%95%B0%E6%8D%AE%E6%94%BE%E5%85%A5%20DTCM%20%E5%86%85%E5%AD%98%E4%B8%AD%E3%80%82%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E4%B8%BA%E4%BA%86%E6%B5%8B%E8%AF%95%E5%B7%A5%E4%BD%9C%E6%B5%81%E7%A8%8B%EF%BC%8C%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%B0%86%E4%B8%80%E4%B8%AA%E5%87%BD%E6%95%B0%E6%94%BE%E5%85%A5%20ITCM%20%E5%86%85%E5%AD%98%E4%B8%AD%E3%80%82%E6%88%91%E6%88%90%E5%8A%9F%E5%9C%B0%E8%AE%A9%20Simulink%2F%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%A8%8B%E5%BA%8F%E5%91%98%E5%B0%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%BC%96%E8%AF%91%E6%8C%87%E7%A4%BA%E8%AF%AD%E5%8F%A5%E6%8F%92%E5%85%A5%E5%88%B0%20C%20%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%23pragma%20GCC%20%E9%83%A8%E5%88%86%E6%96%87%E6%9C%AC%20%22.itcm_text%22%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3Estatic%20void%20Motor_Drive_Subsystem(void)%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3E%7B%3CBR%20%2F%3E%20..........%3CBR%20%2F%3E%20%7D%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3E%23pragma%20GCC%20%E9%83%A8%E5%88%86%E6%96%87%E6%9C%AC%E2%80%9C%E2%80%9D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%E7%BC%96%E8%AF%91%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%EF%BC%8Cgcc%20%E4%BC%9A%E5%BF%BD%E7%95%A5%E8%BF%99%E4%BA%9B%E7%BC%96%E8%AF%91%E6%8C%87%E7%A4%BA%E8%AF%AD%E5%8F%A5%EF%BC%8C%E5%B9%B6%E5%B0%86%E4%BB%A3%E7%A0%81%E6%94%BE%E7%BD%AE%E5%9C%A8%E6%A0%87%E5%87%86%E7%9A%84%20.text%20%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%E9%83%A8%E5%88%86%E3%80%82%E5%8F%AF%E4%BB%A5%E7%94%A8%20objdump%20%E5%91%BD%E4%BB%A4%E5%BE%97%E5%87%BA%E7%BB%93%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3Earm-none-eabi-objdump%20-h%20Motor_Control.o%3C%2FEM%3E%20%EF%BC%88%E5%8D%B3%20.o%20%E6%96%87%E4%BB%B6%EF%BC%89%E7%94%B1%E5%8C%85%E5%90%AB%20Motor_Drive_Subsystem%20%E5%87%BD%E6%95%B0%E7%9A%84%20c%20%E6%96%87%E4%BB%B6%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%EF%BC%89%3C%2FP%3E%3CP%3E%E6%B2%A1%E6%9C%89%20.itcm_text%E5%88%97%E8%A1%A8%E4%B8%AD%E5%8F%AA%E6%9C%89%20.text.xxxx%20%E6%AE%B5%EF%BC%88%E4%BB%A5%E5%8F%8A%E5%85%B6%E4%BB%96%E9%9D%9E%E6%96%87%E6%9C%AC%E6%AE%B5%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E7%BC%96%E8%AF%91%E6%97%B6%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20MBDT%20%E7%8E%AF%E5%A2%83%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%20gcc%20%E6%A0%87%E5%87%86%E5%BC%80%E5%85%B3%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3Earm-none-eabi-gcc%20-O2%20-c%20-std%3Dc99%20-fshort-enums%20-funsigned-char%20-fstack-usage%20-ffunction-sections%20-fdata-sections%20-g%20-pedantic%20-Wall%20-Wextra%20-fmessage-length%3D0%20-funsigned-bitfields%20-fno-common%20-Wunused%20-Wstrict-prototypes%20-Wsign-compare%20-Werror%3Dimplicit-function-declaration%20-mcpu%3Dcortex-m7%20-mthumb%20-mlittle-endian%20-mfloat-abi%3Dhard%20-mfpu%3Dfpv5-sp-d16%20-DD_CACHE_ENABLE%20-DI_CACHE_ENABLE%20-specs%3Dnano.specs%20-specs%3Dnosys.specs%20--sysroot%3D%22C%3A%5CMATLAB_Add-Ons%5CToolboxes%5CNXP_MBDToolbox_S32K3%5Ctools%5Cbuild_tools%5Cgcc_v10.2%5Cgcc-10.2-arm32-eabi%5Carm-none-eabi%5Cnewlib%22-DSTEP_GPT_TIMER%20-DSTEP_GPT_CHANNEL%3DGptConf_GptChannelConfiguration_StepTimer%20-DSTEP_GPT_CHANNEL_FREQ%3D40000000%20-DSTEP_GPT_CHANNEL_VALUE_MAX%3D4294967295%20-DAUTOSAR_OS_NOT_USED%20-D__MW_TARGET_USE_HARDWARE_RESOURCES_H__%20-DGCC%20-DS32K3XX%20-DS32K396%20-DCPU_S32K396%20-DENABLE_FPU%20-DMPU_ENABLE%20-DMBDT_INIT%20-DCLASSIC_INTERFACE%3D0%20-DALLOCATIONFCN%3D0%20-DTERMFCN%3D0%20-DONESTEPFCN%3D1%20-DMAT_FILE%3D0%20-DMULTI_INSTANCE_CODE%3D0%20-DINTEGER_CODE%3D0%20-DMT%3D0%20-DTID01EQ%3D0%20-DSTACK_SIZE%3D64%20-DRT%20-DMODEL%3DMotor_Control%20-DNUMST%3D1%20-DNCSTATES%3D0%20-DHAVESTDIO%20-DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS%3D0%20-IC%3A%20.....%20%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E9%80%9A%E8%BF%87%E4%BF%AE%E6%94%B9%E7%94%9F%E6%88%90%E7%9A%84%20C%20%E4%BB%A3%E7%A0%81%E6%96%87%E4%BB%B6%E5%B9%B6%E6%89%8B%E5%8A%A8%E7%BC%96%E8%AF%91%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%BE%97%E5%87%BA%E4%BB%A5%E4%B8%8B%E7%BB%93%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%E7%A7%BB%E9%99%A4%E5%87%BD%E6%95%B0%E7%9A%84%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%E5%B9%B6%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E9%97%AE%E9%A2%98%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E7%A7%BB%E9%99%A4%E2%80%9Cstatic%E2%80%9D%E5%B9%B6%E4%BD%BF%E7%94%A8%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%EF%BC%8C%E5%8D%B3%E5%9C%A8%E5%87%BD%E6%95%B0%E4%B8%8A%E6%B7%BB%E5%8A%A0%E5%B1%9E%E6%80%A7%E8%AF%AD%E5%8F%A5%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3Estatic%20void%20__attribute__((section(%22.itcm_text%22)))Motor_Drive_Subsystem(void)%3B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E5%B0%86%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%20.itcm_text.o%20%E6%AE%B5%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%98%AF%E6%88%91%E6%93%8D%E4%BD%9C%E6%9C%89%E8%AF%AF%E8%BF%98%E6%98%AF%E5%B7%A5%E5%85%B7%E5%87%BA%E4%BA%86%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%9C%89%E4%BA%BA%E8%83%BD%E6%8C%87%E5%AF%BC%E6%88%91%E5%A6%82%E4%BD%95%E6%89%8D%E8%83%BD%E8%AE%A9%E5%AE%83%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%BD%93%E7%84%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B8%8C%E6%9C%9B%E5%B7%A5%E5%85%B7%E9%93%BE%E8%83%BD%E5%A4%9F%E5%A4%84%E7%90%86%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%8C%E8%80%8C%E4%B8%8D%E5%B8%8C%E6%9C%9B%E5%9C%A8%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E5%90%8E%E6%89%8B%E5%8A%A8%E4%BF%AE%E6%94%B9%20C%20%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%3CP%3E%E6%8D%AE%E6%88%91%E6%89%80%E8%A7%81%EF%BC%8C%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%20startup_cm7.s%E3%80%82%E5%B9%B6%E5%87%86%E5%A4%87%E4%BA%86%20linker_flash_s32k396.ld%20%E6%96%87%E4%BB%B6%E6%9D%A5%E5%A4%84%E7%90%86%20ITCM%20%E5%92%8C%20DTCM%20%E5%AD%98%E5%82%A8%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E7%AF%87%E5%B8%96%E5%AD%90%EF%BC%8C%E4%B8%8D%E7%A1%AE%E5%AE%9A%E6%98%AF%E5%90%A6%E4%B8%8E%E6%AD%A4%E7%9B%B8%E5%85%B3%EF%BC%9A%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio%2FNo-GCC-11-4-item-in-new-project-wizard-dialog-on-S32DS-3-6-2%2Ftd-p%2F2134523%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio%2FNo-GCC-11-4-item-in-new-project-wizard-dialog-on-S32DS-3-6-2%2Ftd-p%2F2134523%3C%2FA%3E%3C%2FP%3E%3CP%3EMBDT%20gcc%20%E7%9A%84%E7%89%88%E6%9C%AC%E4%BC%BC%E4%B9%8E%E6%98%AF%201728%EF%BC%8C%E8%80%8C%E5%B8%96%E5%AD%90%E4%B8%AD%E4%BF%AE%E5%A4%8D%E7%9A%84%E7%89%88%E6%9C%AC%E6%98%AF%201803%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8F%90%E5%89%8D%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Gcc%20ignoring%20pragma%20statements%20to%20place%20code%20into%20ITCM%20memory.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404585%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%20MathWorks%20%E7%BD%91%E7%AB%99%E4%B8%8A%E7%9A%84%E4%BB%A5%E4%B8%8B%E9%A1%B5%E9%9D%A2%EF%BC%8C%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E8%87%AA%E5%AE%9A%E4%B9%89%E5%AD%98%E5%82%A8%E7%B1%BB%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fwww.mathworks.com%2Fhelp%2Fecoder%2Fug%2Fcontrol-data-and-function-placement-in-memory-by-inserting-pragmas.html%23mw_2cafc0af-c99b-4336-84bd-ae46168dd01f%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%3E%E9%80%9A%E8%BF%87%E6%8F%92%E5%85%A5%E7%BC%96%E8%AF%91%E6%8C%87%E7%A4%BA%E6%9D%A5%E6%8E%A7%E5%88%B6%E6%95%B0%E6%8D%AE%E5%92%8C%E5%87%BD%E6%95%B0%E5%9C%A8%E5%86%85%E5%AD%98%E4%B8%AD%E7%9A%84%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FA%3E%3CBR%20%2F%3E%E6%82%A8%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%E7%9A%84%E9%83%A8%E5%88%86%E6%98%AF%E2%80%9C%E8%A6%86%E7%9B%96%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%8A%9F%E8%83%BD%E5%92%8C%E6%95%B0%E6%8D%AE%E7%9A%84%E9%BB%98%E8%AE%A4%E5%86%85%E5%AD%98%E6%94%BE%E7%BD%AE%E2%80%9D%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786627722302.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394557iDF6DC155469603E8%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_0-1786627722302.png%22%20alt%3D%22SorinIBancila_0-1786627722302.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786627722302.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786627722302.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786627722302.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%88%9B%E5%BB%BA%E8%87%AA%E5%AE%9A%E4%B9%89%E5%AD%98%E5%82%A8%E7%B1%BB%E5%90%8E%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%85%8D%E7%BD%AE%E6%A8%A1%E5%9E%8B%E4%BB%A5%E5%8A%A0%E8%BD%BD%E5%AE%83%EF%BC%9A%3CBR%20%2F%3E%3CBR%20%2F%3E%200.%20%E5%88%9B%E5%BB%BA%E5%B9%B6%E9%85%8D%E7%BD%AE%E8%87%AA%E5%AE%9A%E4%B9%89%E5%AD%98%E5%82%A8%E7%B1%BB%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_5-1786628332348.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394565i955F51145FD2B085%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_5-1786628332348.png%22%20alt%3D%22SorinIBancila_5-1786628332348.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_5-1786628332348.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_5-1786628332348.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_5-1786628332348.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E1.%20%E8%BF%9B%E5%85%A5%E4%BB%A3%E7%A0%81%E9%80%8F%E8%A7%86%E5%9B%BE%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_1-1786628013296.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394559iF731C26A35D132D5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_1-1786628013296.png%22%20alt%3D%22SorinIBancila_1-1786628013296.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_1-1786628013296.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_1-1786628013296.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_1-1786628013296.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E2.%20%E5%BC%80%E6%94%BE%E5%BC%8F%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BC%96%E7%A0%81%E5%99%A8%E5%AD%97%E5%85%B8%EF%BC%88%E6%A8%A1%E5%9E%8B%EF%BC%89%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_2-1786628097732.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394560i8662B0A5242070B5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_2-1786628097732.png%22%20alt%3D%22SorinIBancila_2-1786628097732.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_2-1786628097732.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_2-1786628097732.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_2-1786628097732.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E3.%20%E5%8A%A0%E8%BD%BD%E4%BD%A0%E4%B9%8B%E5%89%8D%E5%88%9B%E5%BB%BA%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E7%B1%BB%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_3-1786628212316.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394561i3CFC7F7D5B8DAA32%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_3-1786628212316.png%22%20alt%3D%22SorinIBancila_3-1786628212316.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_3-1786628212316.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_3-1786628212316.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_3-1786628212316.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E4.%20%E5%9C%A8%E6%A8%A1%E5%9E%8B%E5%86%85%E9%83%A8%EF%BC%8C%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%E5%AD%90%E7%B3%BB%E7%BB%9F%E5%B9%B6%E5%B0%86%E5%85%B6%E8%AE%BE%E7%BD%AE%E4%B8%BA%E5%8E%9F%E5%AD%90%E7%BA%A7%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_6-1786628433580.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394566i134E0B0E9B0A9147%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_6-1786628433580.png%22%20alt%3D%22SorinIBancila_6-1786628433580.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_6-1786628433580.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_6-1786628433580.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_6-1786628433580.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E5.%20%E5%9C%A8%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E4%B8%AD%EF%BC%8C%E8%AE%BE%E7%BD%AE%E6%89%A7%E8%A1%8C%E5%87%BD%E6%95%B0%E7%9A%84%E5%86%85%E5%AD%98%E9%83%A8%E5%88%86%EF%BC%9A%E2%80%9CMemSection_ITCM%E2%80%9D%EF%BC%8C%E5%A6%82%E8%87%AA%E5%AE%9A%E4%B9%89%E7%B1%BB%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%E9%82%A3%E6%A0%B7%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20576px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20576px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20576px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20576px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_7-1786628826071.png%22%20style%3D%22width%3A%20576px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394567i2E5D62D40F440FAB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_7-1786628826071.png%22%20alt%3D%22SorinIBancila_7-1786628826071.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_7-1786628826071.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_7-1786628826071.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_7-1786628826071.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E6.%20arm-none-eabi-objdump%20%E6%AD%A3%E7%A1%AE%E6%8A%A5%E5%91%8A%20ITCM_ToggleDIO.o%20%E5%B7%B2%E5%8A%A0%E8%BD%BD%E5%88%B0%20.itcm_text%20%E4%B8%AD%E5%AD%98%E5%82%A8%E5%99%A8%E9%83%A8%E5%88%86%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20823px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20823px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20823px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20823px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_8-1786631977524.png%22%20style%3D%22width%3A%20823px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394569i4F159709A2060278%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_8-1786631977524.png%22%20alt%3D%22SorinIBancila_8-1786631977524.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_8-1786631977524.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_8-1786631977524.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_8-1786631977524.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3Earm-none-eabi-nm%20-n%20s32k3xx_dio_s32ct.elf%20%E8%BF%98%E6%8C%87%E5%87%BA%EF%BC%8CITCM_ToggleDIO%20%E4%BD%8D%E4%BA%8E%200x0%20%E5%9C%B0%E5%9D%80%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_9-1786632086079.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394570i9E483F829B1A8FFA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_9-1786632086079.png%22%20alt%3D%22SorinIBancila_9-1786632086079.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_9-1786632086079.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_9-1786632086079.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_9-1786632086079.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E4%BB%8E%20S32DS%20%E7%83%A7%E5%BD%95%20.elf%20%E6%96%87%E4%BB%B6%EF%BC%8C%E5%B9%B6%E5%9C%A8%3CSPAN%3Es32k3xx_dio_s32c_ITCM_ToggleDIO%20%E5%87%BD%E6%95%B0%E5%86%85%E9%83%A8%E4%BD%BF%E7%94%A8%E6%96%AD%E7%82%B9%EF%BC%8C%E5%88%99%E5%9C%A8%E5%8F%8D%E6%B1%87%E7%BC%96%E8%A7%86%E5%9B%BE%E4%B8%AD%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E6%8C%87%E4%BB%A4%E6%98%AF%E4%BB%8E%200x0%20%E5%9C%B0%E5%9D%80%E5%BC%80%E5%A7%8B%E5%AD%98%E5%82%A8%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786632484317.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394571i8ABCF986BC4C2B9E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_0-1786632484317.png%22%20alt%3D%22SorinIBancila_0-1786632484317.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786632484317.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786632484317.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786632484317.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%B4%A2%E6%9E%97%C2%B7%E7%8F%AD%E5%A5%87%E6%8B%89%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Gcc%20ignoring%20pragma%20statements%20to%20place%20code%20into%20ITCM%20memory.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405278%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%B4%A2%E6%9E%97%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%BD%93%E6%97%B6%E7%A1%AE%E5%AE%9E%E6%98%AF%E6%8C%89%E7%85%A7%20Mathworks%20%E7%BD%91%E7%AB%99%E4%B8%8A%E7%9A%84%E8%AF%B4%E6%98%8E%E6%93%8D%E4%BD%9C%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%9E%E7%8E%B0%E4%BA%86%E7%94%A8%E5%B1%9E%E6%80%A7%E8%AF%AD%E5%8F%A5%E4%BB%A3%E6%9B%BF%E7%BC%96%E8%AF%91%E6%8C%87%E7%A4%BA%E8%AF%AD%E5%8F%A5%E6%8F%92%E5%85%A5%E6%95%B0%E6%8D%AE%E7%9A%84%E5%8A%9F%E8%83%BD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8Cgcc%20%E4%BB%8D%E7%84%B6%E6%8B%92%E7%BB%9D%E5%B0%86%E8%AF%A5%E5%87%BD%E6%95%B0%E6%94%BE%E5%85%A5%20.itcm_text%20%E6%96%87%E4%BB%B6%E4%B8%AD%E3%80%82%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%E5%9D%97%E7%94%9F%E6%88%90%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RNJ_0-1786705067074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786705067074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786705067074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786705067074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786705067074.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394643i404B76887A0F4090%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RNJ_0-1786705067074.png%22%20alt%3D%22RNJ_0-1786705067074.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_0-1786705067074.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_0-1786705067074.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_0-1786705067074.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E4%B8%BA%E5%A6%82%E4%B8%8B%E5%87%BD%E6%95%B0%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3E%3CEM%3E%2F*%20%E5%B0%86%E6%A0%87%E5%87%86%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E9%87%8D%E5%AE%9A%E5%90%91%E5%88%B0%20ITCM%20*%2F%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3E__attribute__%20((section(%22.itcm_text%22)))%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3Estatic%20void%20Motor_Drive_Subsystem(void)%3CBR%20%2F%3E%3C%2FEM%3E%20%3CEM%3E%7B%20....%20%7D%3C%2FEM%3E%3C%2FP%3E%3CP%3E%E7%BB%93%E8%AE%BA%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E.o%20%E6%96%87%E4%BB%B6%E4%B8%AD%E4%B8%8D%E5%AD%98%E5%9C%A8%20itcm_text%20%E6%AE%B5%E3%80%82%E6%96%87%E4%BB%B6%3C%2FLI%3E%3CLI%3EGcc%20%E5%AE%8C%E5%85%A8%E4%BC%98%E5%8C%96%E6%8E%89%E4%BA%86%E8%BF%99%E4%B8%AA%E5%87%BD%E6%95%B0%EF%BC%88%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%8F%8D%E6%B1%87%E7%BC%96%20.o%20%E6%96%87%E4%BB%B6%E7%9C%8B%E5%88%B0%EF%BC%89%E3%80%82%E6%96%87%E4%BB%B6%EF%BC%89%3C%2FLI%3E%3CLI%3E%E5%A6%82%E6%9E%9C%E6%88%91%E7%A7%BB%E9%99%A4%E7%94%9F%E6%88%90%E7%9A%84%20.c%20%E6%96%87%E4%BB%B6%E4%B8%AD%E5%87%BD%E6%95%B0%E7%9A%84%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%E6%89%8B%E5%8A%A8%E9%87%8D%E6%96%B0%E7%BC%96%E8%AF%91%E5%90%8E%EF%BC%8C%E6%88%91%E5%B0%86%E5%BE%97%E5%88%B0%20.itcm_text%20%E6%96%87%E4%BB%B6%E3%80%82.o%20%E6%AE%B5%E6%96%87%E4%BB%B6%E3%80%82%3C%2FLI%3E%3CLI%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%E5%AF%BC%E8%87%B4gcc%E7%BC%96%E8%AF%91%E5%99%A8%E5%BF%BD%E7%95%A5%E4%BA%86%E5%B1%9E%E6%80%A7%E5%89%8D%E7%BC%80%E3%80%82%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%20Modelsim%20%E4%B8%AD%E5%B0%86%E8%AF%A5%E4%BB%A3%E7%A0%81%E5%9D%97%E8%AE%BE%E7%BD%AE%E4%B8%BA%E2%80%9C%E5%8F%AF%E9%87%8D%E7%94%A8%E5%87%BD%E6%95%B0%E2%80%9D%EF%BC%8C%E5%B8%8C%E6%9C%9B%E8%BF%99%E6%A0%B7%E5%8F%AF%E4%BB%A5%E7%A7%BB%E9%99%A4%E9%9D%99%E6%80%81%E5%A3%B0%E6%98%8E%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RNJ_1-1786705067131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_1-1786705067131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_1-1786705067131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_1-1786705067131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_1-1786705067131.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394642iBEC72EEAA612B878%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RNJ_1-1786705067131.png%22%20alt%3D%22RNJ_1-1786705067131.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_1-1786705067131.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_1-1786705067131.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_1-1786705067131.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E5%BE%97%E5%88%B0%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3E%E4%BB%8D%E7%84%B6%E6%B2%A1%E6%9C%89%20.itcm_text.o%20%E6%AE%B5%E6%96%87%E4%BB%B6%3C%2FLI%3E%3CLI%3E%E7%94%9F%E6%88%90%E7%9A%84%20C%20%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8C%E8%AF%A5%E5%87%BD%E6%95%B0%E4%BB%8D%E7%84%B6%E5%A3%B0%E6%98%8E%E4%B8%BA%E2%80%9C%E9%9D%99%E6%80%81%E2%80%9D%E5%87%BD%E6%95%B0%E3%80%82%3C%2FLI%3E%3CLI%3E.o%20%E6%96%87%E4%BB%B6%E7%9A%84%E5%8F%8D%E6%B1%87%E7%BC%96%E6%96%87%E4%BB%B6%E6%98%BE%E7%A4%BA%20gcc%20%E4%BF%9D%E7%95%99%E4%BA%86%E6%B1%87%E7%BC%96%E4%BB%A3%E7%A0%81%E4%B8%AD%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E8%BF%B9%E8%B1%A1%E8%A1%A8%E6%98%8E%E5%AE%83%E6%8C%87%E5%90%91%20.itcm_text%20%E6%96%87%E4%BB%B6%E3%80%82%E9%83%A8%E5%88%86%3C%2FLI%3E%3C%2FUL%3E%3CBR%20%2F%3E%3CP%3E%E9%82%A3%E4%B9%88%EF%BC%8C%E9%97%AE%E9%A2%98%E6%98%AF%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%EF%BC%88Simulink%20%E6%88%96%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%BC%96%E7%A0%81%E5%99%A8%E4%B8%AD%E7%9A%84%E8%AE%BE%E7%BD%AE%EF%BC%89%E8%BF%98%E6%98%AF%20gcc%20%E4%BC%98%E5%85%88%E4%BD%BF%E7%94%A8%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%E8%80%8C%E4%B8%8D%E6%98%AF%E2%80%9Cattribute%E2%80%9D%E5%A3%B0%E6%98%8E%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Gcc%20ignoring%20pragma%20statements%20to%20place%20code%20into%20ITCM%20memory.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405797%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%BE%88%E9%AB%98%E5%85%B4%E4%BD%A0%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%81%20%3CLI-EMOJI%20id%3D%22lia_grinning-face-with-smiling-eyes%22%20title%3D%22%3Agrinning_face_with_smiling_eyes%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%B4%A2%E6%9E%97%C2%B7%E7%8F%AD%E5%A5%87%E6%8B%89%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Gcc%20ignoring%20pragma%20statements%20to%20place%20code%20into%20ITCM%20memory.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405779%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%95%8A%E5%93%88%EF%BC%81%3C%2FP%3E%3CP%3E%E6%97%A2%E7%84%B6%E2%80%9Cstatic%E2%80%9D%E5%A3%B0%E6%98%8E%E6%98%AF%E5%AF%BC%E8%87%B4%E6%88%91%E9%97%AE%E9%A2%98%E7%9A%84%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%E9%85%8D%E7%BD%AE%E5%8F%82%E6%95%B0%E4%B8%AD%E7%9A%84%E4%BB%A3%E7%A0%81%E7%94%9F%E6%88%90%E9%83%A8%E5%88%86%EF%BC%8C%E5%8F%91%E7%8E%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22RNJ_0-1786969749323.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786969749323.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22RNJ_0-1786969749323.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394758i71A6E3F62F83ADA2%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22RNJ_0-1786969749323.png%22%20alt%3D%22RNJ_0-1786969749323.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_0-1786969749323.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ERNJ_0-1786969749323.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%8F%96%E6%B6%88%E5%8B%BE%E9%80%89%E5%90%8E%E9%97%AE%E9%A2%98%E5%B0%B1%E8%A7%A3%E5%86%B3%E4%BA%86%EF%BC%81%3CBR%20%2F%3E%E6%B2%A1%E6%9C%89%E9%9D%99%E6%80%81%E5%A3%B0%E6%98%8E%E5%87%BD%E6%95%B0%EF%BC%8C%E4%BD%86%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%98%A0%E5%B0%84%E6%96%87%E4%BB%B6%E4%B8%AD%E7%9C%8B%E5%88%B0%20itcm_text%20%E6%AE%B5%E3%80%82%E5%A6%82%E6%9E%9C%E4%BD%A0%E4%B9%9F%E8%AE%A4%E4%B8%BA%E8%BF%99%E6%98%AF%E6%9C%80%E4%BD%B3%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E6%88%91%E5%B0%B1%E6%BB%A1%E6%84%8F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%8C%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Gcc%20ignoring%20pragma%20statements%20to%20place%20code%20into%20ITCM%20memory.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E9%87%8D%E7%8E%B0%E6%82%A8%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E7%94%9F%E6%88%90%E7%9A%84%E5%87%BD%E6%95%B0%E4%B8%8D%E5%8C%85%E5%90%AB%E2%80%9Cstatic%E2%80%9D%E5%85%B3%E9%94%AE%E5%AD%97%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-center%22%20image-alt%3D%22SorinIBancila_0-1786963037855.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SorinIBancila_0-1786963037855.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394752iE0B9D6A9F2168088%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22SorinIBancila_0-1786963037855.png%22%20alt%3D%22SorinIBancila_0-1786963037855.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESorinIBancila_0-1786963037855.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%BA%E4%BA%86%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E6%88%91%E5%8A%A0%E8%BD%BD%E4%BA%86%E4%B8%80%E4%B8%AA%E5%9F%BA%E6%9C%AC%E7%A4%BA%E4%BE%8B%EF%BC%88s32k3xx_dio_s32ct%EF%BC%89%EF%BC%8C%E5%B9%B6%E5%B0%86%E6%89%80%E6%9C%89%E6%A8%A1%E5%9D%97%E7%A7%BB%E5%8A%A8%E5%88%B0%E4%B8%80%E4%B8%AA%E5%AD%90%E7%B3%BB%E7%BB%9F%E4%B8%AD%EF%BC%8C%E5%B0%86%E5%85%B6%E9%85%8D%E7%BD%AE%E4%B8%BA%E5%8E%9F%E5%AD%90%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%B9%B6%E4%BD%BF%E7%94%A8%20MemSection_ITCM%20%E5%AE%9A%E4%B9%89%E3%80%82%E4%BD%A0%E8%83%BD%E8%AF%95%E7%9D%80%E4%B9%9F%E8%BF%99%E6%A0%B7%E5%81%9A%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E6%B2%A1%E6%9C%89%E9%87%8D%E7%8E%B0%EF%BC%8C%E5%8F%AF%E8%83%BD%E6%98%AF%E4%BD%A0%E7%9A%84%E6%A8%A1%E5%9E%8B%E4%B8%AD%E6%9F%90%E4%BA%9B%E8%AE%BE%E7%BD%AE%E5%BC%BA%E5%88%B6%E7%94%9F%E6%88%90%E7%9A%84%E5%87%BD%E6%95%B0%E6%98%AF%E9%9D%99%E6%80%81%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3CBR%20%2F%3E%E7%B4%A2%E6%9E%97%C2%B7%E7%8F%AD%E5%A5%87%E6%8B%89%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
