Export generated code in MBDT for S32G series to S32DS
gcohen
I need a way to export MBDT/Simulink generated code for S32G3 into the S32DS. I have seen a lot of discussion regarding the use of the Project Info XML import wizard in S32DS, however, it seems the ProjectInfo.xml can only be generated in MBDT for MPC and S32K series (not S32Gx).
What are my options for accomplishing this task, whether it be still using the XML import wizard or a different way to import entirely?
