Error occured while building model
Ganesh808
I was building the model to flash on PCB board I was getting error SPI_Model I tried every thing all the simulation blocks which are Spi block and Dio block there is no error but at last step it is telling we cannot build the model elf file is not generating. Please guide me through it.
SorinIBancila
I've tried to reproduce the problem but with no success. If possible, can you share the model and the configuration project to have a look?
Sorin Bancila
%3CLINGO-SUB%20id%3D%22lingo-sub-2340606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EError%20occured%20while%20building%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2340606%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20was%20building%20the%20model%20to%20flash%20on%20PCB%20board%20I%20was%20getting%20error%20SPI_Model%20I%20tried%20every%20thing%20all%20the%20simulation%20blocks%20which%20are%20Spi%20block%20and%20Dio%20block%20there%20is%20no%20error%20but%20at%20last%20step%20it%20is%20telling%20we%20cannot%20build%20the%20model%20elf%20file%20is%20not%20generating.%20Please%20guide%20me%20through%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2361019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Error%20occured%20while%20building%20model%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2361019%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EI've%20tried%20to%20reproduce%20the%20problem%20but%20with%20no%20success.%20If%20possible%2C%20can%20you%20share%20the%20model%20and%20the%20configuration%20project%20to%20have%20a%20look%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESorin%20Bancila%3C%2FP%3E%3C%2FLINGO-BODY%3E
