Accelerator Mode Error in MATLAB.
fayesha
Accelerator Mode Error in MATLAB. It says mlib.h file not found. This error is not triggered while running in normal
brianmckay
Hi @fayesha ,
This looks like a MathWorks error, quite likely not related to the NXP MBDT.
You will likely get a better answer by contacting MathWorks Support: https://www.mathworks.com/support/contact_us.html
Cheers,
-Brian
fayesha
Hey @brainmckay
This issue was discussed with MathWorks and it was suggested by them that this issue is from the NXP MBDT side. I have attached images of the error below.
