A problem about capture the frequency of the hall signal
1,245 次查看
wbj5238
Follow the example (BLDC_ClosedLoop_mpc5744p), I just made a model to capture the frequency of the hall signal. The frequency of the signal cannot be measured correctly.  connect the PA2 with PA0.
Attached is the Simulink model. Can you help me see what the problem is ?
NXP Model-Based Design Tools
Thanks you
look forward to your reply.
WangBingjian
1,148 次查看
adriantudor
Hi Wang,
Please let me know if the file that i gave you for Etimer issue solves this problem too.
Thank you,
Adrian
1,148 次查看
constantinrazva
Hello wbj5238@163.com ,
This is the link to the fix adriantudor‌ is referring to.
Kind regards,
Razvan.
