unable to open USB problem
1,125件の閲覧回数
mehmetekici
Hi All,
I have been trying to run  MFS USB example unfortunatly it gaves errors. I am not much familiar  with USB stack and hope I can solve the issue with your guidance. I have enabled the stack's log and the output is enclosed.
I use a custom board based on TWRK60D100M, MQX4.0 and CW10.4.
Mehmet
Original Attachment has been moved to: usbproblem.txt.zip
ラベル(2)
タグ(2)
0 返答(返信)
