spi slave support
spi slave support
1,171 次查看
kirankunnath
     We are using MQX 4.0 for one of the project. We need spi slave configuration for that.
Will MQX 4.0 support spi slave configuration? Is there any latest version available that supports spi slave?
Kiran
1 回复
1,038 次查看
soledad
Hi Kiran,
Unfortunately slave is not supported by the MQX driver. It is master mode only.
For master mode you have two options:
1.  ProcessorExpert bases spi driver.
2. Write your own driver for spi slave using direct accesses to DSPI module registers and call it from an MQX task.
Sol
