qsqlite missing from fsl-image-qt5-validation-imx
terry1
Got these message when running a qt app that uses sqlite.
QSqlDatabase: QSQLITE driver not loaded
QSqlDatabase: available drivers:
terry1
Downloaded qt-everywhere-src-5.10.1.tar.xz, built(not easy, takes a long time) and installed. Sqlite is now working, looks like the Yacto supplied qt is incomplete.
Also a platform linuxfb is now available and working.
joanxie
I don't think i.mx products qt supports this, you can refer to the qt forum:
https://forum.qt.io/topic/55860/qsqlite-driver-does-not-load
terry1
Why are you pointing me at windows information, the imx8 is linux.
Terry
joanxie
I just searched from google, you need to check if current bsp has this driver firstly,  try to refer to the qt forum, I searched a link, hope helpful for you
https://doc.qt.io/qt-5/sql-driver.html
