how to know connected host system IP?
sudhakarp
     i am using frdmk64. and using kds2.0 and ksdk1.1.0 example.  i want to know connected host(or remote) system ip address.
if any function  there? i am listening one port but i dnt know which IP was connected to my device.
how to get  IP address of Remote(Host) System.
regards,
sudhakar p
danielchen
I think you can get the ip address by getpeername(),  Please check the MQX RTOS RTCS User's guide for details
7.2.33   getpeername()
Gets the remote endpoint identifier of a socket.
Synopsis
uint32_t getpeername(
uint32_t socket,
sockaddr * name,
uint16_t * namelen)
Have a nice day,
sudhakarp
hi,
actually i tried following method is it correct..?
client_sock = accept(conn_sock, NULL, NULL);
getpeername(conn_sock,&addr,sizeof(&addr));
printf("Remote IP=%u\n\r", ((sockaddr_in*) &addr)->sin_addr.s_addr);
but i am getting ZERO only
OUTPUT
Remote IP=0
     give some other idea.
regards,
sudhakar p
sudhakarp
Hi daniel,
thanks for your information. I got solution for this.
instead of this i tried
client_sock= accept(conn_sock, &remote_sin, &remote_addrlen);
printf("\nConnection accepted from %lx, port %d",
          remote_sin.sin_addr, remote_sin.sin_port);
regards,
sudhakar p
