got an error in IAR embedded workbench while executing CAN code took from freescalemqx4.1
sreevenkedesh
friends please help me to solve  the error while running a can code on iar embedded workbench for freescalemqx4.1
error:- Fatal Error[Cp001]: Copy protection check, No valid license found for this product [24]
thanks in advance
soledad
Do you have this issue only with the CAN code? In my opinion this is an IAR license issue, I would recommend you to contact IAR Customer service:
http://www.iar.com/Service-Center/Customer-service/
Sol
