creating an MQX 4.1 project
1,178 次查看
josecaballero
Hi, I am creating an MQX 4.1 project but when i have to select the board the window shows empty and i cannot choose any option, so i cannot move forward, could you lease tell me what is wrong?
2 回复数
1,108 次查看
danielchen
You  also need to check whether your MQX package is installed in the default place [ C:\Freescale\Freescale_MQX_4_1 ], otherwise, maybe you will encounter this issue.
1,108 次查看
danielchen
Hi Jose:
I guess maybe you need a patch, which IDE and version you are using?
