can't operate flexbus in MQX
712 次查看
davidzhu
Hi Support:
I am working on a custom k60 board with MQX.
I can not operate the flexbus to manage a my external device that needs 8-bit data bus, a CS, a RD, a WR.
Is there anyone who has managed to make it work?
Thanks .
614 次查看
danielchen
Hi David:
I would suggest you refer to AN4393, Using Flexbus interface for Kinetis MCU.
https://www.nxp.com/docs/en/application-note/AN4393.pdf
Pay more attention to the BSP initialization flexbus and flexbus pins.
Wish it helps
