Undefined reference to d4dlcd_frame_buffer
1,403 次查看
ankurchauhan
Hi...
I'm using d4d demo code to display string on LCD.
I'm getting error like :
-> undefined reference to d4dlcd_frame_buffer
for the following code  :
D4D_LLD_LCD.D4DLCD_Send_PixelColor(p_CharDes->colorBack);
(void)D4D_LLD_LCD.D4DLCD_SetWindow(p_CharDes->x, p_CharDes->y,
i have definitions of D4DLCD_Send_PixelColor and D4DLCD_SetWindow.
what could be the problem.
Ankur
标记 (1)
1 回复
1,300 次查看
EarlOrlando
Senior Contributor II
Hello Ankur,
This function is part of the D4D low level drivers and is declared in the file common_source\d4d_lldapi.h so please confirm that it is included in your project. I recommend you to take a look into the demo projects that are included in the NXP Embedded GUI Software​.
Earl.
