To porting K60 to K66
1,639件の閲覧回数
anand_s
Hi all,
       i am using an application based on  KINETIS K60 mcu ,with OS: MQX 4.02 version. Now we want to upgrade the same to K66 MCU, and by referring some notes i understood that MQX 4.02 doesn't support K66. So i checked here and got a Porting pdf regarding that. I gone through the document but its hard for me to understand because i am a beginner for this. Also updating MQX 4.02 to MQX 5.0 is also not possible for us. Is there any easy way for that..Can anyone help me out..?
k66‌,  #mqx 4.02 with k66‌
タグ(2)
2 返答(返信)
1,517件の閲覧回数
danielchen
Hi ANAND:
Just as you said, the easiest way to use K66 with MQX is MQX v5.
Please refer to below link
MQX™ v5 Software Solutions | NXP
Porting to K66 is recommended to an experienced user. You can refer to the document MQX_BSP_Porting_Example_User_Guide.pdf and MQX_BSP_Porting_Guide.pdf.
It is not an easy job, you can start with MQX 4.2.0 with TWR-K65, since K66 is similar to K65.
1,518件の閲覧回数
anand_s
Thank you..:)
