Taks kill in MQX
Taks kill in MQX
1,101 次查看
sarath_gs
I want to know about the status of a task which is running in MQX is there any functions for this ? also what is the task kill function in MQX? in linux pthread_kill , like is there any function in MQX?
1,041 次查看
danielchen
Hi Sarath:
I would suggest you check the API
_task_get_td.
You can get the task descriptor , then you can check the state from the task descriptor.
2.1.274 _task_get_td
Gets a pointer to the task descriptor for the task ID.
Prototype
source\kernel\task.c
void *_task_get_td(
_task_id task_id)
For the task kill function, you can check
2.1.260 _task_destroy
Destroys the task.
Prototype
_mqx_uint _task_destroy(
_task_id task_id)
I hope it helps
