TWRVF65GS10-MQX USB host application host_ch9 functions not working
manjug
When i call host_ch9 function to request device for getting descriptor it's not getting the descriptor values in my host application code-
case USB_DEVICE_INTERFACED:
status=_usb_host_ch9_get_descriptor(usb_device.DEV_HANDLE,
  USB_DESC_TYPE_DEV<<8, 0, USB_DESC_LEN_DEV,
  (unsigned char *)&dev_ptr->dev_descriptor);
if (status != USB_OK)
       printf("\r\n no descriptor from ch9functions");
   e = _lwevent_get_signalled();
  if (USB_EVENT_DATA & e) {
  if(usb_device.DEV_STATE == USB_DEVICE_INUSE) {
  break;
  else{
  usb_device.DEV_STATE = USB_DEVICE_INUSE;
  break;
  if (USB_EVENT_CTRL & e) {
  /* kick the outer loop again to handle the CTRL event */
  _lwevent_set(&USB_Event, USB_EVENT_CTRL);
  break;
  break;
I have attached my host application code file.Please help me on this.
Original Attachment has been moved to: xl4usbip_host.h.txt.zip
Original Attachment has been moved to: xl4usbip_host.c.txt.zip
alejandrolozan1
Are you getting a kind of error like USBERR_DEVICE_NOT_FOUND or USBERR_INVALID_PIPE_HANDLE? or maybe you are just getting a buffer with 0 data.
/Alejandro
alejandrolozan1
It has been a while, I wonder if you have solved the problem.
/Alejandro
